Hi folks, I tried rooting my VM LG Volt with towelroot, and it told me my device was unsupported. Is there another app I can use to root the Volt? This Mobile ID sh
Did you download the latest update?
There wouldn't be a point in fastbooting into a different kernel if you're on v4, because of you were even on v4 you wouldn't have access to fastboot unless you were already rooted. Otherwise if you're looking for an already rooted v4 ROM there already is one in the forums.
good point, i didnt think of that. i read earlier that zv4 update restores the laf partition, and it must have just totally went over my head. lack of sleep will do that. makes sense that to access fastboot you have to wipe the laf partition, which requires root lol.
i had a nexus device for so long that i kinda got lazy and quit following root exploits and the such, is towelroot the only game in town anymore for one click root?
When I try to use this is says device not supported. Using boost mobile LG Volt...
Hmm, this sounds like stuff out of my league. I'm wondering if I should just return this phone and call it a loss. It's rather annoying that this version of the software can't be rooted without open heart surgery.
Then you're on v4. You will have to roll back to v3 then root and use the v4 update posted here. All the info is in this forum.
Anyone had problems with this phone yet??
wanna say thanks for this thread. worked like a charm! I wound up buying two from Radio Shack as well. It's strange that the one I opened for me was V3 and my wife's phone was V4. Lucky me, huh?![]()
You should still be able to downgrade the one on v4 though.
His wife probably doesn't care about rooting.
