Sepero
Linux Guru
PROBLEM:
If your phone is rebooting 3 or 4 (or more) times per day, then that is not normal behavior. Constant rebooting seems to be a common problem with some LG Motion 4G users. There are a variety of solutions to this problem, and currently, these appear to be the causes:
STEP 1:
You may want to backup your contacts and MMS/SMS history with an app like Go Backup Pro (any suggestions for other backup apps are very welcome).
If your phone is rooted, you should unroot your LG Motion 4G phone.
Factory reset your phone. Press the Menu button from the Home screen > System Settings > Backup & reset > Factory data reset
(Power on your phone holding: Power + Vol Down)
STEP 2:
Now that you have your phone back to a factory fresh state, play with it a little and see if you can get it to spontaneously reboot. If everything seems okay, go to STEP 3.
Otherwise you very likely have a defective phone. Your options:
STEP 3:
Reinstall your backup app. Restore your contacts, restore your SMS/MMS, and edit all your desired system settings. Test your phone out for a few hours or days. If everything seems okay, go to STEP 4.
Otherwise you likely have a defective phone, but there is a small possibility that there may be a weird settings glitch causing the problem. Your options:
STEP 4:
Reinstall your favorite apps. Disable any system apps you don't want. Use your phone for a few more hours or days. If everything seems okay, go to STEP 5.
Otherwise you likely have a defective phone, but there is a small possibility that there may be a weird settings or apps causing the problem. Your options:
STEP 5:
If you reached this point, then your phone should be behaving properly. If your phone was previously rooted, then your problem was likely caused by some modifications you performed while using root.
If you do not wish to root your phone, then you are finished with this guide. End. Cheers.
UNDER CLOCKING:
This section is for people whose phones are randomly rebooting, and you have not yet rooted your phone.
To underclock your phone, you will now need to root your phone. Root your phone following the ROOT YOUR PHONE section. Then, install an app like No-Frills CPU Control. Set your Maximum clock frequency to always run at the lowest setting (check "Apply on boot"). Press the "Apply" button.
If your underclocked phone works well for several hours or days, then your random rebooting was likely a result of over heating CPU. (You should try to have your phone replaced by the manufacturer if you can.) Your phone will probably be able to operate safely around 1.026Ghz. Try to gradually increase the frequency speed on your phone until you find the frequency you are comfortable with.
ROOTING YOUR PHONE:
Click the following link to find the LG Motion 4G root guide.
Be careful about removing any system apps, as they can be known to cause continuous rebooting. A safer solution is to simply disable undesired system apps. If you discover a system app that you believe causes system reboots, please let us know.
Any suggestions for improvements to this guide are welcome, please leave a post. Cheers
- Phone is over clocked, or over heating.
- Deleted a necessary system app.
- You used the Automated All Bloatware Removal script.
- Possibly messed up system settings???
STEP 1:
STEP 2:
- If your phone is still under warranty (1 year manufacturer warranty for MetroPCS), then take it back and they should replace it for free, or a minimal fee.
- Your CPU may be over heating/misbehaving. Go to the UNDER CLOCKING section of this guide.
STEP 3:
- Leave us comment saying what Settings you think might be causing the problem, and try going back to STEP 1.
STEP 4:
- Leave us comment saying what changes you think might be causing the problem, and try going back to STEP 1.
- If you can demonstrate that your phone is misbehaving and it is still under warranty (1 year manufacturer warranty for MetroPCS), then take it back and they should replace it for free, or a minimal fee.
STEP 5:
UNDER CLOCKING:
ROOTING YOUR PHONE:
