sammyz
LG Whiz Kid
Help after flash no touchscreen
Factory reset
Yes, it's the 11A. I don't feel comfortable using something that's meant for an entirely different phone =/ Do I have any other options?
i tried the best with google translator
Glad it worked!
In my experience, it's not necessary to wipe root before updating. It'll update just fine, but you'll lose root. It should be possible to update and preserve root using OTA Rootkeeper. I updated from 10A to 11A, and Rootkeeper was able to preserve root.
My phone refused to update to 12A, wouldn't even download it, so I used the KDZ full flash method which wiped root and Framaroot was able to get root back. If the OTA will work for you, then I think Rootkeeper would still be able to preserve root but I don't know that for sure.
I updated because I had numerous bugs with 11A, like lock screen would just stop working. The lock screen problem seems solved on 12A so far.
