Root [GUIDE] UOT Kitchen
Since you only tried once, try again. By time range, I meant how long did you get the error for. For example, if the first time you tried was at 3:15, then you tried again at 4:30 and still got the error, then tried at 7:15, the time range would be 4 hours, from 3:15 to 7:15.
I found out what it was and it was the animations
so animations dont work or you will get a bunch of errors
welcome but now i have another problem i made the status bar black and i over wrote the apks and the black bar doesnt want to show help?
I have a similar problem, but with a background image. The image shows ABOVE notifications instead of below them, forgot to put this in the guide. I am currently working on a way to fix the problem manually.
