Root [GUIDE] ZTE vital/supreme Unbrick Guide
stevestone
Here we go,
Below are the steps to unbrick zte vital or supreme.
In case if you can boot up in recovery, please do data/cache wipe.. if not then its not an issue, This is required as we need some space in data partitions..
Hold volume up + power, It will boot up in FTM mode .. Make sure you have proper ADB installed. As it works fine with ADB and su..
please copy cwm recovery.img or system.img or boot.img in your relative path of ADB folder.
Code:
adb devices
See, If your devices get detected.
Then
Code:
adb shell
su
mount -o rw,remount -t ext4 /data
chmod 777 /data/media/
exit
exit
After that for flashing recovery.img follow this steps..
Code:
adb push recovery.img /data/media/
adb shell
su
dd if=/data/media/recovery.img of=/dev/block/platform/msm_sdcc.1/by-name/recovery
reboot recovery
for system.img follow this steps.
Code:
adb push system.img /data/media/
adb shell
su
dd if=/data/media/system.img of=/dev/block/platform/msm_sdcc.1/by-name/system
reboot
System.img will take some time, If in case you dont have space in data partition, Then please flash cwm recovery first then do factory format (data & cache wipe)
Our data partition have enough space to accommodate system.img :D
but after wiping it off..
Thanks..
Sorry for bad english
Code:
[B]adb shell[/B]
reboot recovery
Code:
[B]adb shell[/B]
reboot
its cuz you werent in adb shell after pushing the file, ive bolded the steps that steve should add to clarify for people :)
HTML:
c:\SDK>adb shell
shell@android:/ $ dd if=/data/media/recovery.img of=/dev/block/platform/msm_sdcc
.1/by-name/recovery
 of=/dev/block/platform/msm_sdcc.1/by-name/recovery                           <
/dev/block/platform/msm_sdcc.1/by-name/recovery: cannot open for write: Permissi
on denied
thanks shabby.. Hey venture please see it again. I updated it... you are not doing su..
please do it from start again.. It works 100%, I tested..
:D
LOL.. I guess.. Actual gift should be given to developer JUNKIE.. for porting CWM..
I dont know his paypal email..
This might work for other ZTEs too. flash...
this should actually work on any 8960 or newer zte. in theory anyhow, cooldudezach also let me onto something that i believe he got from you shabby, that will allow you to recover from dfu mode, its slightly more complex of a solution that requires a dump of the entire internal chip as a whole, bootloader, radio partition, everything, but when youre down to nothing but a black screen and a red light you have little choice
i would however add in a rm command after the dd process, that way it deletes the system.img and/or recovery.img, and it could easily be turned into a script if you like. pack it all up and leave less room for user error
and i appreciate the thought but i cant accept donations, paypal sucks. i have a donation link but it wont let me take the money out without a bank account and i dont have a bank account... and im not really out bounty hunting here, if i was i wouldnt focus on ztes lol. i just wanna help the little guy, make sure that these budget phones dont get overlooked while every developer and their mom makes stuff for samsungs and lgs
umm... that i dont know, something about the dfu mounting the entire internal chip in linux as a block device via usb or somethin
yea i know nothign of that, i assumed you were talking about in the event of bootloaders being overwritten you boot off teh sdcard to get into dfu mode.
maybe that was it... i could swear i heard you mentioned, i also recall somethin about scary alien... i dunno it all kinds blurs together at this point lol
Google wallet card?
Can someone help me by telling me all the steps get do this, like what i need to install and everything for it to recognize my phone? I bricked it and i need help. Please.
What happened was i was messing around with the build.prop and i tried to delete the modified on and put the stock one back but when i restarted my phone is was just a black screen after the android guy and it comes up in stock recovery instead of cwm.
This is because you forgot to set the permissions of the new build prop to rw- r-- ---.
Try factory resetting from the stock recovery. Then tell me if it boots or now. It should boot, but it'll freeze when you turn off the screen. Tell me if it boots first and if it does, I'll tell you how to fix the screen problem
This would be easier...
Code:
adb shell chmod 644 /system/build.prop
Code:
It won't boot at all after the green android guy. And I can't get it to recognize in adb. I honestly don't know what Im going to do.:(
Boot to ftm and use adb. It is the other vol + power button combo. For example, if vol down + power is cwm, then vol up + power is ftm. I don't have a vital so i am unsure which is which.
