Root [GUIDE] ZTE vital/supreme Unbrick Guide
try typing "adb shell". Do you get a new prompt that looks different than before? If so, try typing "chmod 644 /system/build.prop" in the new prompt and see what happens
edit: you probably need su for this
Code:
adb shell
su
Code:
adb shell
su
Adb shell gives me"shell@android:/ $''
then the other line says no file in directory
That is good news :) ADB is working but you don't have a build.prop file. We can easily push the stock one in place, change the permissions, and you should be on your way. Put the stock build.prop file in your adb directory on your pc and fire up a terminal.
Code:
adb push build.prop /system/build.prop
adb shell
su
Code:
adb shell
su
I may sound stupid, but this is where i get confused. Im not sure what you mean by adb directory. If you give me where yours is at ill be able to find where to put it on mine.
Oh and when i type in '" su " it acts like it doesnt have super user permission. It just goes to the next line.
"adb push build.prop /system/build.prop" gives me (error device not found)
Regarding su, it should go to the next line and change the $ to a #.
Regarding the adb directory, you can do something like this
Code:
adb push C:\Users\user\Desktop\build.prop /system/build.prop
I actually have my build.prop there already.
When i type SU in it doesn't change $ to a # it literally just goes to the next line and doesn't say anything except ( su_ )
I feel like that would work but it keeps giving me device not found
Ok, does this work when you replace the build.prop file path to one that actually exists?
Code:
This may sound crazy, but have you tried 1) different usb port 2) different usb cable 3) different computer ?
I changed cords and ports now when i type in that command it said " read only file system " . What line do i use to change it to write? if i am correct.
Wait when if i type in adb shell then that last line it still gives me ' device cannot be found "
Try this
Code:
adb shell
su
mount -o rw,remount -t ext4 /dev/block/platform/msm_sdcc.1/by-name/system /system
If there is, you can download the stock ROM rename it to update.zip and chose that option in recovery. I cant remember the options on the stock recovery.
Alright ill try it. So i just rename " quantum_stock_B06_with_recovery.zip " to " update.zip " and update from external storage?
Put the stock rom on the external sd, rename to update.zip and select the external sd option.
That should get it boot up, then you can install CWM and restore the backup that you hopefully made before messing around with build.prop
I'm assuming you had CWM installed.
That should not work due to the lack of zte's signature on the stock rom. I hope it does though lol.
So im basically screwed?
The only thing I can think of is to find a root method that can be used through adb, then try all the things we did again. You need to be rooted to fix this problem.
edit: motochopper might work.
I tried, it said
Finding update package...
Opening Update package...
Verifying Update package...
Installation aborted.:(:(
Any option on stock recovery to turn off signature verification? I think it failed because its not signed. ( Super R already said that didn't see it until after posting this)You can actually try the Mobster Rom or any Rom for our phone it just has to be renamed update.zip
