6th_Hokage
SuperR is currently working on giving us Boost users a TWRP recovery
I'm using the 1-ClickRoot v1.3 method & phone is in download mode/Firmware update @0%
Command window (on desktop PC) is at "rooting phone" @ 90%,has been there for 10+ minutes.
Should I heed the "Do not unplug until the process is complete" warning,or abort & try again?
MetroPCSwhich variant do you have?
Make sure usbdebbuging, unknown sources and MTP are checked ✔OK,pulled battery & re-booted,no problem,still not rooted.
Tried several times,keeps hanging at every step of the root process,only progresses when switching between MTP & PTP.
Gonna factory reset & start over.....
THX!
Double-checked everything,even tried to run v1.2 & nada.
The d/l I got is missing the ports.bat,perhaps this is causing problems?
Either way,1.3 & 1.2,SuperSu is not installing & not getting root.
I tried that & got some bad s*** on my PC,had to scan w/Malwarebytes & remove.Are you using this link for LG Root Tool v1.2?
http://forum.xda-developers.com/android/development/guide-root-method-lg-devices-t3049772
BRB.......There is no malware in that root. It's a very popular root method with over 40,000 downloads. That's the one I used and had no issues of any kind. Click the blue download button not the orange.
Did you recently bought the phone or had before the lolipop update ?Almost made it through,got to COM,got two of 'em,COM6 &7
Gonna try again....................
Why not use kingroot apk way easier and simpler.Still not rooted,I'm gonna have to call it a night,work beckons in a few hours.
I'll be back on about 18 hrs from now.
THX for all the help everyone.
My apologies regarding the link GT,the orange button is the one that loaded up my PC w/the warez/etc..... it's all good,no harm,operator error on my behalf,please accept my apologies.
Works for me,BRB............................Why not use kingroot apk way easier and simpler.
@EarlyMon can this thread be closed and repost with a different owner ,( can't keep up with two device at a time ) with that said do one of you guys want to get ownership of this thread @GameTheory @Noobified @DrakenFX
