Root gv 2.8
swampymc8
Member
hi
just downloaded this ROM , ( will be first rom installed. )
question being do i need to partition sd card and do i need s-off ?
not done any of these yet dont think i have the no how to do it ( have read and not sunk in )
if need doing can anyone recommened a 2.3 rom that dosent need them
thanks guys
You don't need S-Off.
Partition the SD card if you wish to use a2sd+. It should work without, you'll just be able to install fewer apps. But if you wish to use that, it's probably simplest to do the partitioning first before installing the ROM (though it should also be possible to install it after the fact).
Hi
Read about partitioning but not confident in doing it.
Have read and read bout it but not sinking in. Think will try without partition
