Root GV a2sd and internal memory (again)
barefootpilot
Hi all,
After a long absence I've moved up from GV 2.7 to 3.3. All fine apart from internal memory which is down to about 35Mb.
Run the cache cleaner (aCCleaner) and it found nothing much, run the "a2sd cachesd" command (twice) and still no real improvement. Contacts is only taking up 522Kb.
Just run the "a2sd check" function and seems OK:
apps linked to sd card
dalvik to sd flag file found
ext partition mounted
Any suggestions what might be causing the low memory and what I could try next?
114. Prior to updating I had about 50-60 Mb free, now with no other change apart from moving from 2.7 to 3.3 I'm down to 35.
Roms also take up space on data before anything is installed.
If you're really interested, flash both roms with a clean install and compare
