Help Gyro or no Gyro? (LG G3 D850)
smootskin
Hi Guys,
Does the LG G3 has a Gyroscope?
Its actually hard to belive it doesn't, but i'm getting different results with each smartphone specs at different websites i'm checkig... including gsmarena and phonearena.
So, does it have a Gyroscope? (LG G3 D850)
Thx
It's my understanding that it's more of a Motion Sensor than a Gyroscope. The motion sensor detects tilt and orientation. All models of the G3 (including the AT&T D-850) have a motion sensor.
Have any idea if it'll work well with Google Cardboard?
Up
Anyone have an answer?
It may...not sure but my Verizon model does.
Download either Quick System Info and go to the "Sensor" tab....or Elixir 2 and go to the "Sensors" option.
so, quite possible ?
I even checked PDADB.net & the detailed description doesn't explicitly say GYROSCOPE,but,may very well have it listed/identified w/another moniker, knowledge of these things are above my paygrade.....
http://pdadb.net/index.php?m=specs&id=6218&view=1&c=lg_g3_d850_lte-a_lg_b2
down near the bottom it states, "gyro"
  • capacitive touchscreen
  • Corning Gorilla Glass 3 screen
  • GPRS Class 12
  • HSPA+ 42Mbps
  • HSUPA 5.76
  • LTE 150/50Mbps
  • Real Stripe matrix
  • OIS+
  • HDR photo
  • HDR video
  • BSI sensor
  • 8x digital zoom
  • HD Voice
  • VoLTE
  • Knock Code
  • NFC
  • DLNA
  • Wireless Charging
  • 3G/4G Mobile hotspot
  • proximity sensor
  • light sensor
  • gyro sensor
The other option is to stand the phone on end, and spin it...see if it stays spinning :p :p :o
I all idea is first to make sure it'll support Google Cardboard and then buying it...
Thx anyway :)
Iv'e checked GSMARENA and PHONE ARENA and had different results...
Is PDADB any special?
