bg4m3r
Android Expert
I seem to be having a problem with the Gyroscope Sensor on my phone. I recently flashed CM11 (which is great btw) and noticed that when turning the phone on its side the screen doesn't rotate until I go about another 45deg. To test things I downloaded Android Sensor Box. On the Gyroscope Sensor it seems to be registering 45deg for every 90deg of rotation, so turning the phone upside down (180deg) only rotates the box 90deg. This isn't a huge problem, but it is annoying and I can't find any apps that calibrate at the system level. I found and tried a few Terminal commands, but they didn't help either. Just hoping someone on here had some advice/experience.
I will say now that I enabled all 4 orientations in the CM settings.
