Help Had to do Android update now chrome problem
Yeah, so I had to do the update, and now Chrome replaces the LAST letter in the url bar.
For example, if I'm at Google, then try to go to yahoo, when I SHOULD be able to type "Y" and get "yahoo.com" to auto pop-up, highlighting only the first "y" as usual, it now ADDS a "Y" to the end of the url. I type the "Y" and it puts in "yahoo.coy"
This is highly annoying because I cant use one touch to get my sites as it is. A reset, a reinstall, a desktop sync, nothing has helped. Im ready to toss this phone.
TYIA
TYIA
Hello and welcome to Android Forums AscendedSaiyan! :)
Sorry to hear about your problem. Perhaps you might give Chrome Beta, free from the Play Store, a try and see if that helps.
