Handcent led notification stopped working?
Yeah, there was a thread on it, but I thought they fixed it with a quick follow-on update.
Are you sure you're at the latest/latest?
If so, maybe scroll back a page or two or just search for Handcent LED above - the thread was started by DarkNeo as I recall.
That's the versions (3.2.4) I currently have; but its still not working.
Have you checked the new settings. The LED notification was off as a default. It works great on the newer version. You can select the color (amber/green) and the flash rate. It will also interrupt the charge indicator now as well to notify you while charging.
Go into notification settings then notification settings again and change led flash frequency to normal or fast
Mine doesn't flash while charging. :(
How do you set that feature?I have Froyo now.
Yours flashes to remind you while charging? Mine sure doesn't. Was a restart all you did to invoke that?
I just went through all the notification settings, and there are two extra colors for the led
Blue, green, amber & pink... Blue wont work, and pink shows up as amber on mine
* added stuff
charge light is overridden ( at least when set to pink-->shows up as amber)
