Handcent /Messages
slatyford
Installed Handcent and was wondering if there is a way to disable the native messages application as double messages is starting to become annoying
The other option is to disable notifications in handcent and when you click on the native notification it will ask you which app you want to set as a default.. choose handcent.
Is it not possible to delete Android messages app totally or does Handcent sit on top of it and use it to access the messages?
