Help Handcent notification sound stopped working
athegn
Android Expert
Found this in another thread:-
"..When I select a notification tone in Handcent it plays but whe I test it or a txt arrives nothing.
Both emai and txt notification sounds where working last week..."
I have the same trouble on my S2 in Handcent.
When I go to Handcent > settings > Notification settings > Notification sound I select my sound; it plays, I then click ok. I then try Test Notification. The vibration pattern works but the sound does not. I have sent a text from another phone and that only vibrates; the notification sound does not.
Any Handcent users with any ideas please?
I have discovered that:-
Menu > Settings > sound > Volume > Notification will not stay at anything other than zero.
I drag the slider to the right and get the full power notification sound. I press ok then back out. I send a text from another phone but all I get is the vibration pattern; no sound.
I check:-
Menu > Settings > sound > Volume > Notification and find that the Notification has returned to zero.
Any advice please?
Hopefully fixed by opening Volume Locker and unchecking that, then setting Notification sound then rechecking Volume Locker.
