Help Handcent problem
TokedUp
It wont let me choose contact when starting a new message. Usually when i start to type a contact name it auto finds contacts with those letters. I get nothng now. I uninstalled and re-installed but it happened again.
any help? the stock meesaging app is soooo boring
Hmm, I just tried it on mine and when I started typing it gave me a list of possible contacts like yours used to. I had to tap in the To: field to bring up the keyboard, but after that it worked fine.
Hope you can find a fix. Good luck!
The same thing happened to me for a while, but at the time it was only doing this for certain contacts :confused:
Over time I've noticed now that when I start typing it works perfectly so I'm not exactly sure what caused the hiccup.
Sorry I'm no help in fixing your problem but atleast now you know it's not only happening to you!
