Handcent SMS Issue - Won't sound notification after being on vibrate
When I first start my device, everything works as it should.
If at any point I put my device on vibrate, and then turn the ringer volume back up, Handcent's notification does not return to it's original setting.
Trying to change or update any notification settings has no effect.
The only way to return to the proper notification settings is to power cycle my device.
Is there any way to fix this?
I have tried doing an uninstall and re-install with no help.
Thanks in advance.
