shotgunxbaby3
I received my 2.1 OTA DL last night and all has worked well, the only problem I have found thus far is saving pictures from Handcent SMS to my SD card. It won't let me copy them over for some reason. Anyone know why that is?
I cant even see MMS messages .... it just says downloading. I have one my wife sent me yesterday, and it has been downloading ever sence. Anyone else have this problem or know how to fix it? It says downloadin in both Handcent and the stock message app.
do you have wifi/3g on? i trick myself sometimes by turning it off then getting real pissed that i cant send/receive mms, then i realize i didnt have wifi/3g on.![]()
Try going into Handcent settings. Go to Send SMS Settings, then go to Maximum MMS Size and check the 1M setting.
I know this helped when "sending" pictures and attachments, but not sure if it will help on receiving.
can you view it through your stock message app?
No, I could not.
I called Verizon Tech Support as a last ditch effort. I have found that this site tends to be more helpful then Verizon ... but to my surprise, they said this is happening with a lot of the devices and were able to help.
For anyone else having the same or similar issues ...
1. Soft Reset (Pull battery with the devise on)
2. Dial *22899 and press send. It may take a fw moments, but it will eventually tell you a bunch of tests were successful
3. Dial #832 and press send. It will tell you it was successful
BAM ... MMS works.
Thanks to everyone who responded.
