Root Handset won't boot - help please!
alesro
Hello
I am a new user and please help me!
I have a Htc desire, with root done, and now my phone is dead, on the home screen it shows only a text "android", i can not start it!
Please somebody can help me, what should i do?
If it is a problem with the soft, also please show me the steps i need to do to make it work.
Thank you very much in advance for your support!
did you try to instal anything before this happened, ,turn it off then holdi down power and volume down to get into recovery , then see if there are and backups on there .;)
