hang up to home screen
canrunin
I was on here and found a app that after you hang up the phone from a call it goes right to your home screen so you dont make another call by accident. can any one tell me the name of that app it was great but i dont remember the name????
Ah great -- I couldn't figure out what was bugging me about the end-of-call behavior until you suggested it; that's exactly what I want to keep from redialing the person I just talked to by accident.
It's "Not Call Log" in the market, and it's free. You can select what you want to run (most likely "Home") at the end of a call. Just installed it, seems to do what it says.
I thought there was an option out there to set when you hit your hang up key, it would "return to home", as well. I had that done on my 1.5, but I went to 2.1, and I haven't seen where to re-enable that.
