Unstoppable0
How you doin, guys?
My Desire 816 used to lose internet connection suddenly while browsing web or using apps although everything seems right:
Network signal is strong. The "h" symbol exists normally in the status bar. But with incoming arrow deactivated.
This problem disappears when I restart the device.
Solutions like : disabling mobile data then enabling it Or switching to airplane mode then disabling it donot work.
When I switch network to gsm only mode, the internet come back . But with 2g slow connection. When I switch to gsm/cdma or cdma only I lose internet again .
I hope that you can help!
Thanks in advance
Thanks in advance
