Root Haptic feedback occurring in screen lock!
a5pe4
How do I stop this? There is no feedback any other time. I'm not sure what setting is doing it. The ones I've checked have it off.
Check notification settings in all of your apps. One is likely set to vibrate. It's very easy to overlook and allot are setting that as default.
This sounds like a glitch in the custom ROM. I'm going to move this thread to the All Things Root sub-forum so you can get more rooted members to help figure out your problem.
I'm using the latest BACKside. Can someone try setting a pattern or pin lock and see if they can reproduce this?
Revert back to your backup. If the problem persists it is your phone. If not the ROM is corrupt. Download a fresh ROM and Gapps and use the Update_wiper_1.3.zip found in the All Things Root Guide. Install the wiper zip first (this will allow for a more through wipe) then install the ROM, and gapps.
