Help Haptic feedback ON PHONE DIALER!!
rockokma
Seems to me you can't remove the haptic feedback on the phone dialer.
I would hate to see that this is true, this is the best phone dialer I've had on an android device.
This does remove the tone...but there is slight vibration feedback still, which is impossible to turn off....unless it gets rooted and we can load CM rom ;)
Yeah, haptic feedback doesnt look like it can be taken off, however the dial tone can be.
Sorry to hijack, but what about turning off haptic feedback for texting/text input? While I like it, I find I type faster without it (on other touchscreen devices).
Same problem here. I have both of these turned off and the dialer still has the haptic feedback.
Unchecked: settings>language keyboard>touch input>text input>vibrate when typing
Unchecked: settings>sound and display>Audible touch tones
Any suggestions?
The haptic feedback in the dialer is so that you don't accidentally pocket dial someone. The feedback should let you know that you're actually pressing buttons. It's a security feature. Not a hindrance.
I am just not a big fan of the haptic feedback. If that is the case, then why would they let me turn all the other haptic feedback off and not the dialer. I don't pocket dial people, so I don't need it. I have read that this is an issue on other HTC models as well.
not sure if it's a feature or an issue but is it really that big of a deal?
I may be misunderstanding this thread, but isn't the answer:
Settings>Sounds&Display>Haptic Feedback (uncheck this)?
Correction - this doesn't actually help on the dialer. Sorry. My quest to successfully answer my first question continues......
