Help Haptic feedback vibration - turn off
fascinated
I have turned it off on the keyboard. Is there a way to turn it off on the 4 buttons at the bottom of the screen?
How do you turn it off for the keyboard? I cant find any keyboard settings. I see i just turned off my predictive words while tyoing this but I have no idea how i did it...
Depends which keyboard but you can always go into Settings > Language and Keyboards and go into the settings for whichever keyboard you are using and vibrate or haptic feedback should have an option to uncheck.
