elevenbangbang
What's the key combination to hard reset this? Thanks.
I don't seem to get settings > factory restore.
I have Settings and Display under Settings, but not a factory restore or any choice like it.
So -- any other ideas on a hard reset?
I need to do this because my phone won't connect to the market, etc and people are suggesting to reset and fix the problem.
No, it certainly shouldn't. You will have to reinstall everything you've installed, and re sync your contacts, but it won't erase your SD card.does this also erase the contents of your SD card?
melblank: yes this will erase the contacts. hopefully you're already synced with google. then you just have to re-setup your google account in the phone and your contacts will sync again....
Stoney62: correct me if i'm wrong, but isn't a soft reset the same as a reboot? so on a locked phone, the soft reset is pull the battery....
I'm pretty sure that's a negative... even though it says "reset", it's really only a reboot to get back into android... really just an exit from the diag tool. It definitely didn't hard reset my phone the last time I was in the tool several weeks ago.
