nah, ruu, update.zip, or applied ota is the exact update, if your having issues, do a hard reset and things should improve. and yeah i think this was mentioned![]()
For those who don't know, the RUU was a flash. It wipes everything out of the phone and reinstalls a clean copy of Android 2.2 The OTA was an update. All that does is overwrites your system file and few other files, and that's it. Because of this, you will have compatibility problems with apps installed from 2.1 on 2.1. The same thing happened with Eris & Droid users going from 2.0 to 2.1.
Not being argumentative...just confussed now?...
Either way...I did the reset and see if it helps...
The new android 2.2 update did not catch on my phone. The store said if I hard reset the phone the update would be pushed again. Its that true?
