Help Hard reset
Dinmags
I performed the hard reset and it was successful. But then, why is it that the signal was high but it says there that it is for emergency calls only? I restarted my phone for the nth and it is still the same. What will I do to fix this?
It sounds like you're stuck in emergency mode or emergency call mode - getting out of it varies by device.
That or the phone has defaulted to it as happens when it's not active on a carrier - and that can happen with a bad sim card if I'm not mistaken.
Check Settings, wireless and networks, APN and make sure the correct APN are set (although I think they're only for Internet sorry)
Check Settings, about phone, status and (dont post it here) but do your IMEI code look ok? (16 digits, not all zeros?)
I took my phone to a samsung store. They checked it and they performed program reset. Then they said that it can't be fixed. They also asked if I want them to open it. They also said that the condition will be 50/50. It might not open after opening. So I said no.
