Help Hardware help
Connected the battery to my nexus 7 and tried to put this silver cover back on the mother board and sparks came from the location. Did this damage anything?
Well if you don't know (took me a while to decipher "idk"!) then we certainly don't ;-)
Test everything; if it all works then nothing is broken despite the sparks. Simple as that :-)
It may be your kernel. I've had that problem with a few custom kernels. I know it works on the stock kennel, cm, and the built in kernel on slimkat and liquid smooth.
