Root Harmonia Battery Life
I'm only getting about 10hours of battery life from my Evo V since switching to harmonia, this is with turning the gps off etc.
What is normal and are there any tips/tricks to increase the battery life.
i suggest buying a new battery i got a chichitec 1930mah battery lasts much longer than stock battery :D im on cm 10 too so my battery life was good on some days and bad on others.
I'm on harmonia I have a laza extended battery which is about 3500 mhz it lasts about 2 days with light to moderate use. It might be a rogue app I suggest under clocking to maybe < 1ghz on smartass v2 you can also under volt. If you get juice defender or any other battery saving app it should help save your battery. Mobile network also drains the battery. Just use the sync all widget when you turn on 3g.
