Help Has anyone had problems with the GPS?
I agree that a GPS will never be perfect. But as an owner of several handheld non-phone GPS units, I will say that the GPS in my Stylo is completely worthless..it might as well not have a GPS. All of the apps on my Stylo that use a GPS lose reception frequently and have difficulty navigating from point A to point B, especially Google Maps. The GPS in my older phone worked better. And the problem is not getting a satellite fix, the problem is keeping a lock on the satellites. Oh well, I hope my next phone works better.
Got you... As for me it has been wrkng fine... I knw it a good thing to have but in ph administration if you keep that Google stuuf on it gives you more accurate locations even though if kind of leak just of battery.
Don't try to Uber or Lyft with Stylo. I lost abot $500 over 2 weeks until I figured it out. Tethered my old phone to my new one until I can badger MetroPCS into a replacement.
I am on my 2nd Stylo in 3 weeks - same issues. MapFactor shows 20 satellites locked, then 4 then 0, then back to 20. position on map keeps stopping. LG wants to repair phone. I think I'll just return this and get something else...
Maybe bad batches on production?
I just ran GPS test on my Stylo. Im indoors, not next to windows, old cinderblock building
It locks in about 4 seconds, then negotiates more sats in use, and accuracy goes up.
Let it sit, the in view number never changed, so it didnt lose any.
Google maps, Earth, lock on pretty fast, and show correct maps
20In View , 14-15 In Use (maxed after 3 min)
Accuracy
13feet
Just to be sure, this isnt a military grade device, 13 feet is pretty good.
My 4 month old LG Stylo fails to lock on to GPS, regardless of where I am (indoors or out), leaving me to navigate with network signals only. Trust me, that does not work other than an inducement to road rage. Will be getting a replacement from T-Mobile as soon as I can get my company to authorize the $5 fee T-Mo charges for the privilege. Based on what I read here, I'm thinking I've got a 50-50 chance that the problem will persist. If so, has anyone gotten T-Mobile to give them a different phone (or at least credit the purchase price of the LG to another brand/model)?
Those bastards want me to pay $15.00 for a replacement. So much for warranty.
A couple things I've learned from experience with LG. They are a south korean company, so they don't have the same standards of service as an American company. If I buy a product from a store here and there's a problem with it, most American retailers will stand by the product and offer some sort of refund or exchange for a brand new item. That's an amazing thing, trust me.
When you have a problem with your LG device, the policy they follow is to exchange like for like. No refunds are offered, nothing 'new' is going to be given to you if you get a replacement device. What you will get, is a refurbished phone. Which means someone else had it before you and put a degree of usage on it that you can't assess in order to determine the value of the phone. I bought an LG volt from Virgin Mobile once, and within a week the LED flash stopped working completely. It was spotty at first (loose connection or short) and then just stopped. Could have been a faulty LED. When I contacted LG for my advance RMA, they sent a replacement phone for $25 (I had issue with that too, but shipping isn't free) and the phone ended up being wrapped in bubbles and stuffed in a plain white box. No retail packaging, nothing to indicate that I had a new device.
It appeared to be in perfect condition, but there was no telling how much use it had, so I ended up keeping the defective phone and sending the replacement back (I had just paid $100 for a new phone, not about to trade it for a used phone). Virgin Mobile also refused to do anything to reimburse me or exchange the phone, citing manufacturer warranty policy. So I ended up dropping them and buying the same phone from Best Buy for $60 on Sprint. No issues from that point on (except for tiny phone/big hands problems ^_^)
Now, I've also been having GPS issues with my G Stylo. I ended up getting that phone from Walmart and taking it to T Mobile to activate it (I have the higher specced G Stylo) and haven't had a good working GPS since I upgraded to lolipop and marshmallow. At this point, I'm sure it's a software problem (because the GPS DOES work) with the way these new OS versions have handled GPS. You have to remember that the G Stylo is classified as a phablet too, it's not the same as a regular phone in the scope of device features, so it could be a case of short cuts taken in development to port over Marshmallow for the G Stylo and the device sensors are different enough to require their own version of the GPS drivers, which no one has taken the time to make (yet). Remember, I didn't have issues with this phone when I first bought it. It was only after an update.
There could also be issues with the way Location services are handled in the new OS, it seems to me that forcing Wifi GPS by default would cause accuracy problems if you weren't near enough to Wifi long enough for a good signal. Just picture in your mind, driving down the highway at 60 miles an hour. I know Wifi travels at light speed, but authentication does not and if you pass a hotspot long enough to pick it up but not long enough to connect, wouldn't that just **** up your GPS accuracy if it's switching between your GPS and Wifi antennas? I don't know how to disable Wifi location permanently, but I think that might be a viable fix if someone comes up with it. I don't have my GPS on all the time (battery drain) only when I need it, so having to turn it on then turn off the other crap every time I need it, is too much imo.
I found this on Marshmallow GPS issues. It cured my 6.0 problem:
http://www.express.co.uk/life-style...59/Android-Marshmallow-GPS-signal-trick-boost
I'm not trying to be rude, but I didn't get anything out of that link, it appears to cut off halfway through the article. I'm also unsure how Bluetooth is going to help me get my GPS to stop bouncing all over the place, when it seems like the problem is too many conflicting things trying to use GPS to begin with...
It's nonsensical, but it did fix my Stylo's GPS issue. Here's the complete text, If the mods will let me... XP:
Android’s latest update brings with it a wealth of cool new
features and tweaks to enhance the Android experience.
The latest version of the mobile operating system has
already started to roll out across the globe – and you can
find out when to expect the update here.
However, some Marshmallow-powered Android users have noticed
GPS connectivity struggles to lockdown a location, which is
bad news for those with a bad sense of direction.
Luckily there is a fix for the spotty GPS connectivity.
Unfortunately there will always be times when GPS fails you.
If you find yourself in a particularly built-up area or
somewhere on the edge of civilisation then ultimately the
signal from GPS satellites could become lost in the
ether.Luckily a brand new feature found on Android’s
Marshmallow update will allow your phone to use Bluetooth to
further boost location accuracy.
To put it into action open Settings > Location.
Tap the three dots to reveal the Options menu. Choose
Scanning.
Next you’ll see two options.
Tap on Bluetooth scanning to toggle this feature on/off.
You'll want it turned on.
Congratulations your smartphone now boasts the ultimate
location-aware powers.
Android owners were previously able to take advantage of
other advanced features that satisfied a similar need.
For instance, if you were to delve deep into Location
settings you’d uncover the High accuracy mode that uses a
combination of GPS, Wi-Fi, and cellular networks to
determine your phone’s location.
In Android Lollipop, Google ditched the accuracy tags and
referred to the locating method instead. GPS, Wi-Fi, and
mobile networks is selected by default.
Elsewhere Advanced Wi-Fi hides options that lets Google
continually scan for networks even when your Wi-Fi is
switched off.
(Copyright express.co.uk)
Um, is the GPS antenna supposed to look like this?
http://imgur.com/rrv9ufm
Cuz mine doesn't have any contacts for the pins to touch, maybe that's why it doesn't work?
Could it be that only the NFC antenna is on the back, and is missing from some models? It doesn't jibe with what I understood, but I'm pretty sure some models came with a back without an antenna. ($10 on EBay for backs with NFC, I've read)
I bought two Stylos same time. One worked fine and another had GPS problem from day 1.
I sent the defected one to LG to get it warranty repaired. They fixed quick and I got it right next day (I guess it's easy to fix?) . GPS worked fine for 1 week then went bad again. I sent it back to LG for 2nd warranty repair with stating the problem and ongoing issue. I also made a note that I would rather get it replace / upgrade instead of quick fix.
I should get it back today but what worries me LG system says, it's regarding Power Reset issue and they simply flashed the memory to fix it (uh.. what?)
Defect:
Power-Reset or cycle
Repair Results:
Flash Memory
If this is another temporary patch and GPS goes bad again. I will directly contact LG again, but this is so frustrating switching phones constantly.
Good luck....
I've had GPS issues on this sh!tbox since new. It does lock eventually, but when you move to another area it is stuck at last fix, and needless to say, it doesn't work when you need it to.
Only cure was running something other than factory firmware. While using Katana ROM it worked fine, every time. I don't know if 6.0 upgrade fixes it, I'm rooted and stuck on 5.1 and have no interest in wasting even ten seconds trying to fix it. I'm so done with LG devices lol...
I signed up just to complain about this phone. I've had it for just over a year (June or so of last year) and I've had the same experience as Spec2nirvash above. GPS has been absolute garbage from day 1. Has that "stuck at last fix" problem constantly - often thinks I'm at home when I'm at work 10 miles away and vice versa. When it does report anything, it's usually off by a good 60 feet (often tells me I live 2 streets over), and I assume it only figures that much out with the help of cell towers and wifi. I've never been able to use it for navigation in the car - it doesn't tell me where to turn, it just tells me "GPS signal lost" over and over again. Next to useless when you're standing still, completely useless when you're moving.
When I bought it it was on Android 5.x and I'm now on Android 6. I haven't noticed any difference; GPS has always sucked, on both OS versions. I'm tempted to try this Katana ROM thing but I don't want to downgrade from 6.
The comments here aren't very encouraging with regards to getting the hardware repaired, and I don't want to buy a new phone just because I'm frustrated trying to play Pokemon Go (Which, again, is an absolute nightmare with this defective GPS).
The only reason I didn't exchange it immediately is I didn't use GPS frequently. I liked everything else about the phone. I've had an old HTC Evo 4G (Android 2.3) before this and its GPS was perfect.
First off let me say I'm sorry you've been neglected or neglected yourself with an HTC EVO 4G I had that as well. But it became garbage. Considering the stylo has been out for a little over a year you missed all the cool stuff from jelly bean to lollipop. When i still had my LG G Stylo functioning i had it rooted and installed Katana ROM. Didn't fix the GPS issue for me. I had that phone from the day it came out. GPS never worked. So Katana ROM might fix your GPS issue, it might not. Let my LG G Stylo rest in piece. Not only did I crack the screen by having it in my back pocket for the first time ever. I never put phones in my back pocket. Then Marshmallow came out. I was going to flash back to stock and update then root marshmallow. Something went wrong while trying to flash back to stock and now it is bricked. Since then I am now on T-Mobile running with the LG V10.
At this point I am glad at least map & navigation work. Occasionally it drops GPS signal due to weak connection but at least it takes me to the destination. Come on LG...
My GPS doesn't seem to work with any navigation app. Very in accurate. Already checked settings, settings are fine. Still doesn't work though, any ideas as to why it's not working.
Unfortunately when this phone upgraded to Marshmallow, I lost ALL GPS function. It was spotty before that, but at least it worked sometimes. What REALLY sucks is I'm a Lyft driver and rely on GPS. Oh, and I can't play Pokémon Go!, with no GPS. Sad.
