averagewonder
@averagewonder
There is a new thread for LG Stylo 2. It Covers that new Variant. It would be best to ask that over in that thread.
Yeah I looked at that it seems to be just for the 2 not the 2 plus.
@averagewonder
Im having the same intermittence with a twist. My gps will re align to my home address. But if I turn my location on and off, I am found momentarily until the location turns off again on its own. One of the tools suggests my proximity sensor is not functioning. Can anyone else confirm this? BTW, this did not happen from day one. I feel like this may be driver/software related.
Not sure why I didn't Google this issue before, I've been dealing with GPS related issues while driving with Google Maps for MONTHS. Finally contacted T-Mobile regarding warranty and getting a replacement tomorrow.
I suppose I hesitated since I had the phone rooted and figured it had something to do with that. Seeing this thread has changed my perspective!
If the replacement has the same issues I think it's safe to say I'm done with LG. The Stylo 2 Plus looks nice, but I'd rather go back to a budget Samsung that functions as it should. I guess we'll see!
My solution was this: with the newly found confidence of having a replacement battery cover, I GENTLY peeled back the adhesive holding the 2 square contacts on the inside of the battery cover, and placed about a 1/8 inch thick piece of foam adhesive beneath the contacts (I had some leftover window seal foam and used an exacto-blade to cut out the small rectangle needed). I then slowly slid the battery cover back on, trying to make sure that the contacts would line up, and snapped it into place. Other than a very small bulge on the back cover, everything fit snugly back together (I use a case so this isn't an issue, someone else could probably cut a slightly thinner piece of foam and be ok).
In my attempt to remove the battery cover to take some photos, I learned quite a bit.
I also ordered a new battery cover and am waiting on it to arrive. I did try that trick also yesterday, as I read it on another forum to create a shim under the antenna contacts on the cover. I also watched a video on how to do it on youtube and the instructor used a small cut piece of card board from the back of a notepad. I did not have much luck with it working for me that is why I neglected to mention it before. I also carefully removed the NFC antenna from the back cover and replaced it slightly higher. After attaching the cover and then removing it again, I noticed two NEW small dimples in the gold contacts slightly lower than the original deeper marks, so I know it is touching the pins. Still no GPS signal most of the time but perhaps a little better. I hope the new battery cover helps.
I believe the back cover is NFC alone, while GPS antenna is inside the back housing cover. Perhaps I may try dismantling my Stylo and see if I can spot a bad connection...
LG G Stylo is clearly design flow / manufacturer defect. Just got my LG G Stylo back from LG (3rd time warranty fix) still GPS is choppy. I am planning a family trip so I just switched my phone back to Samsung Avant.. better safe than sorry. GPS Risk too high.
Well after searching through the internet for over 4 months ... I found what seems to be the issue.. If you take off the cover and check every single screw .. You might notice they are a tad lose.. Tighten all of them without stripping them and but the cover back on and check your gps... It fixed mines and some other ppl (source reddit)
Hmm.. that actually may help. A friend who works in LG told me that the GPS antenna / connection part is lose on this device so they had to support it with small cushion for new batches.
Anyway I am going to RMA send it for 4th time. When it returns I am going to check screw myself and see if it helps![]()
