Has anyone seen better battery life on stock rom 4.0.3
atmasters
I have been going threw lots of the treads and it seems like there are a lot of us that have had big issues with Battery life when updating to ICS 4.0.3 I did not have all that good battery life with GB but it has not gotten any better with ICS either. So does anyone get good life with just the stock update ?
For me I do enjoy ICS it has not given me much problems just a little over heating but minor at this stage and that I cant get threw the day on battery. Other than that I like it. how are you liking it ??
Intially the battery life went down to just a few hours , but now i am getting 1.5 to 2 days with internet use.
I also switched my e-mail program from the stock to another and it might be this that has made the dramatic difference?
My S2 is all stock, no root, with Bell, i'm getting better battery life since the ICS
update, my guesstimate would be 20%-30% better.
thats crazy that some of you can get that much out of your battery. Are you using stock roms or having to set your phone up just right or are you just running it like it came out of the box ?
