Yes I can see my folders but when I press on a folder there isn't any mail in there. I can only see the new mail I get in my Inbox after I put the email into the phone.So...I think you are saying that you are trying to access your gmail account through the htcmail app, right?
If so, then you added the account however nothing came up, If you press Menu, then Folders, you can see all your folders listed. Am I getting close?
Amazing thanks it fixed it for me. Is K-9 really better then the HTC mail app?When in mail app, go into the settings. Under, I believe it is, Schedule, the default is 3 days. Check All or a different amount if desired.
I may be wrong about what menu it is, since I removed the HTC mail app from my phone. I'm using K-9. However, it is there because I had the same issue when I first started using it.
