Have a question about saving pictures
jackbquick123
I used to could go anywhere with dolphin or other browsers and long press a picture and it would give the option to save,, but since I installed jelly bean I no longer have that option.
Does anyone know the work around for that ,, maybe change a setting like we used to do to take the appl@ law suite restriction things and put them back on by changing things in system.
Also I read in here the other day about changing true and false and enabling the cubed apps drawer and lots of other things but I have searched and looked for a while now and cant find it. If anyone remembers where it is at could you post a link or tell me where its.
Thanks in advance
If you're talking about the inverted cube home screen launcher effect it's in feature.xml. that will enable that effect. Just make sure you save it after you change it to true and then reboot
Thanks in advance
I have no trouble long presing on an image and then doing a view of the image and also saving it. I am on JB. The onlky thing I had to do with dolphin and JB was to side load flash then go back to an olderversion of dolphin (the new ones won't let you enable flash if on JB) then once I set flash to be on always, I updated dolphin to the latest and all works fine. I do like to use the browser in desktop mode,
to get the tilt effect on the launcher you edit the feature.xml located in system/csc. Note: check the permissions attributes on the file before editing it and make sure you set them back to the same way once you save the file (the editor in ES file manager has a bad habit of changine them when you edit the file and save it).
Okay thanks everyone. I have side loaded adobe but after the last dolphin update it won't let me turn flash on and I can't save anymore. Oh also it crashes while going to my bank site.
Dolphin is my favorite browser but have been trying boat.
I will try and get older version of dolphin and see what happens.
Thanks
Thanks
Take a look back in the older threads I posted about that and i think I had links to the older dolphin too
Fount it:
http://androidforums.com/galaxy-s2-...546-jelly-bean-flash-fallout-work-around.html
Once again codegerm,,, you rock!! Works great.
I think it's stupid to pull flash and stop supporting it this early in the ball game cos were just not ready for it yet.
Just like pushing electric cars on us when there are no public plug in stations. Lol
jmo
The funny thing is the YouTube app that is on our phones has flash embedded in it. Flash is still widely used and is everyone "guilty pleasure".
Oh and I also use the dolphin jet pack
I spoke to soon,, flash works but still won't save pics.
I tried jet pack on another phone and it didn't play nicely but will try it again since it works for you.
after i did flash and got it working I updated dolphin to the latest
Now your web site may be running a java script to prevent the download menu.
