Hi guys and gilrs,
decided today to do the whole root thing on the pad, all went well, loaded z4root and turned out was already rooted, ideal,
so! downloaded tims rom tothe computer, popped the mempory card out the side, but no sign of a Root directory anywhere on it! so thought i'd pop the card out the pad and check that, opened it al up, carefully and safely, popped the card out and put it in the reader ont he netbook, search as much as i could No root directory anywhere! on opening the card up had a winzip folder and 3 other sections, checked space on it and turned out to be only 140mb on the card! - meant to be a 4gb,
so copied the files off the card to the netbook, formatted the card and checked again, 140mb, got my 4gb card i'd been using in the pad for music etc and formatted that, copied the files over to it and put it in the pad, turned it on and sits on the android man in the middle of the screen, nothing more,
turned off, popped the card out and removed the tims rom bits and put it back, got the same,
stuck now!
and somehow the 140mb card has dissapeared!! feeling the littlun picked it up and put it somewhere?? trying to find it is pure needle in haystack time lol!
Is there a way i can format a card, put firmware on it, plug it in and return the pad to normal?????
stuck now!
