Root Have NO PRL? HELP
killa57
Okay i Have rooted the 2.2.1 Optimus m i checked with terminal emulator and did get a # i have super user permission
the only thing i cant figure out is why i have no service? i guess it has to do with the PRL right? cause thats the only thing that is missing on the LGNPST when it gives my phone info I have tried dialing #228 but get no where with it it just says "Programming Unsuccessful please contact customer service" the Original PRL that it came with is 3015 from whats on the original package it came with. I only had this phone two days b4 i started messing with it so any clues on where to get the PRL and how to load it using LGNPST? Do i have to add a bin file, src file, and PRL file or do i only load the PRL file?
Did you include the prl file like instructed when you "upgraded"?
If so did you follow the steps qouted below to restore service?
Reboot your phone and check if you got service. To install new Recovery Menu for 2.2. phones and get service back go to this thread Then install a program from market called anreboot. Install the app and open it up, then select reboot system. If everything went alright your phone will restart and it will have service and will be rooted.
To verify root go to market download terminal emulator from Jack Pal. Then open it up and type su, if you get # you are successfully root.
yes i added it it was the 3017 i believe i rebooted my phone after the sdk commands and i did not get any service dont know why? so i continued to the custom recovery and for some reason after i rebooted to recovery i ended getting service after the full boot and the PRL showed up now i was able to update it as well#228 now i have the 3018 prl thank you for your quick response
*SOLVED*
