Hey guys,
New to the tablet world and so far, not bad, something to get used to I guess. I've been running into a few problems and I've read the forums and haven't found the correct advice. I do however need to check the forums for one of my 3 issues... will do.
1. Wifi is weak - I've downloaded and installed the most current firmware update and it's not very strong. I'm in the next room with thin walls and I'm down to 1-2 bars. When I'm in the living room (where the router is) I get 3 bars (20 feet away). While I'm at work I only get 1 bar and I'm about 30 feet away. Anyway to increase the Wifi?
2. I took a video today and I wanted to transfer it to my computer but there were no options. I've tried a few things and done research but can't seem to find a solution. I did however change the settings now to record on the SD card from this point further. Ideas? (RESOLVED)
3. I downloaded app2sd which I've heard is a great program to store your apps on your sd card. Card has been formatted as Fat32. Option to transfer it over however, is not there. I heard it works on some and sometimes it doesn't work. Is there a solution to this?
Thanks to all that take the time to help and hopefully one day after I learn what the hell I'm doing, I may be able to return the favor and help others.
CCRichter
CCRichter
