Help Having a longer ringtone?
Kayfaei
I'm really loving this phone..only thing I do not like is that it seems that my phone rings only a mere seconds before it goes to voice mail, sometimes I'm to far away to reach it in time.Also, I love hearing my ringtone play all the way through (29seconds) Is there anyway I can change the time of how long my phone actually rings to maybe 30seconds before voicemail picks up? instead of the 5-10 seconds it seems to do.
As though you were going to make a call, type in *#61*11#
Then press the green phone button as though calling someone.
Make a note of the number including a + sign if there is one, and the amount of seconds.
If it's showing less than 30 seconds, type in **61*(x)*11*30#
Press the green button. Note (x) has to be replaced by the number you get from the query, and without the brackets.
The first code is query.
The second is set.
After setting, use query again to check.
Are you using one of the ringtones that came with the phone, or one that you downloaded? Is the volume high enough that you can hear the entire ring tone from the beginning?
