kens97sto171
Member
Gmail wont send or recieve new mail.. it just sits there sending forever. I have also noticed the data activity and synch going even when I am not doing anything. and I have run ATK to kill any apps that might be using data.
Something is not right.. Also per my previous issues with the SDCARD messing up.. I formated it, but in the gallery it is acting wierd.. it shows the photos, then they go away, then come back.. and sometimes you can not click on them to go into a group.. like camera. If you run ATK and kill the gallery then try again.. sometimes that makes it work. I bought a new 8Gig Class 4 card, tested it first, and tried it in the phone, but I get the same behaviour. It's almost like the "file allocation table" has been corupted, and the phone is having trouble "seeing" whats in the folder. I formated the card, let android re-create all the folders, took a picture, let android create the camera folder, then put all my pictures back in that created folder... still not working right.
At this point I am thinking of just wiping the phone, OS and all. I still have the update.zip file from the 2.1 OTA leak, If I just redo that procedure will it overwrite the OS? and allow me to start from scratch?
Sorry for the long post.. but a lot it going on, and it is getting frustrating.
Thanks
Ken
Thanks
Ken
