Having GPS issues?
skinien
I've seen several posts about people having issues getting location based services to work quickly and accurately. My location based services (including navigation) are working perfectly, so I figured I'd make sure people knew about the location settings in a new thread.
Go into Menu -> Settings -> Location
There are three options:
I'm pretty sure when the phone ships, all of the location settings are NOT enabled.
-VZW location services
-Google location services
-Standalone GPS
VZW location services: Uses cell towers to get general location
Google location services: Uses wireless networks to get general location, but more accurate than using cell towers
Standalone GPS: Uses GPS antenna to get position. Accurate up to a couple meters (outside of course). You may have problems getting a lock in certain buildings - but GPS is meant to be used outside. :)
I leave VZW and Google services on all of the time and turn off Standalone GPS when I don't need to use maps. That way, if a widget (like the weather widget) needs to get a location, it doesn't spend the time/effort to get a GPS fix. Getting a general location using VZW and/or Google location services is basically instant.
I hope this helps a few of you out there.
