Hi i just bought the nexus s from bestbuy, but it seems forced to close the phone call frequently...is it some kind of software problem or hardware problem??? the software version is 2.3.1 though...i need some help plz~~
Hi i just bought the nexus s from bestbuy, but it seems forced to close the call frequently...is it some kind of software problem or hardware problem??? the software version is 2.3.1 though...i need some help plz~~
I sugest you go with the new 2.3.4 manual update, I have a ns i9020t manual updated to 2.3.4 and I haven't get bug (any gps issue or reboot or anything I had before) try this and let me know if it resolved the issue
This was a known issue that was fixed with the 2.3.3 update. The latest update is 2.3.4 which still includes all of the 2.3.3 fixes as well as some new ones and new features. You can either wait for the OTA to 2.3.4 to come to your phone, or you can manually update it by following this guide: http://androidforums.com/nexus-s/327991-guide-manually-update-2-3-4-2-3-2-2-3-1-a.html
