silentshadow86
Well, it might be Liberty, it might not. Basically, since I switched ROMs to Liberty 1.5 from nandroid, I have been experiencing unresponsiveness and reboots every once in a while. For the most part, my phone seems faster and more responsive on Liberty, but sometimes when I try to 'wake' it, it doesn't respond. After trying to click the sleep/wake button a couple of times, it either reboots itself, or I have to do a battery pull. I also notice that sometimes it will crash and reboot while using certain apps like Pandora. This does not happen nearly as often, but its worth mentioning. The sleep/wake issue is my main problem. Has anyone else had this problem or know how to fix it? Please let me know if it is the ROM so I can try another one. I don't want to switch and have the same problems, it takes too long to restore all of my settings and data...
My phone did reboot itself every once in a while on nandroid too, but it was more after an overload of apps/data was being used, I didn't have the sleep/wake problem.
Thanks for any help!
