Root Having problems with rooting
m4h1r
i have rooted my acer a500 but then formatted the system back to factory settings, now whenever i try to install the iconica-root-1.3 it say that there are some problems occurred. please help me get my device rooted
dont worry i have rooted it but one other question i have downloaded the games spider man hd and backstab but when i try and install it it says installing data but it cancels everytime, so can you tell me how to download the data files and how i am supposed to install it. another question what type of format do you have to convert movies to, to watch it on hd on the tablet
as for your 2 games i can't answer but to convert movies i use dvdfab 8 and ipad.mp4 profile
ps: i use my legally bought movies, wich is we all should do :-)
does anyone know how to remove a preinstalled app, my tablet is rooted i just dont know how to remove a preinstalled app? any ideas?
My tablet only arrived this morning, so I am brand new to tablets, but have had my rooted Desire HD for a year. All I can say is, be careful what you remove... some apps are baked in to the system and could end up breaking your device.
It is possible to use Titanium Backup to freeze bloatware (this doesn't remove it, but stops it from working/draining system resources/battery power).
What is it that you actually want to remove?
documents to go is the preinstalled app(free version) i want to remove, i want to remove it so i can install docs to go pro full version, because whenever i try to install the full version it says there is already an installed version. any ideas of removing this ??
