Lord Foolber
hi im having trouble getting my phone to root using superone click, i get to step 7 and it says this. my phone is a commando version 2.3.3. i have no idea what all this means, any help? im assuming its something that its saying toward the end...
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
$ export PS1=""
getprop ro.build.version.release > /data/local/tmp/output 2>&1
export TEMPRANDOM=75440
export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output
2.3.3
END:75440export PS1=""
getprop ro.product.manufacturer > /data/local/tmp/output 2>&1
export TEMPRANDOM=17654
CASIO
END:17654export PS1=""
getprop ro.product.model > /data/local/tmp/output 2>&1
export TEMPRANDOM=35669
C771
END:35669export PS1=""
getprop ro.build.version.incremental > /data/local/tmp/output 2>&1
export TEMPRANDOM=92630
user.build.20120911.111646
END:92630export PS1=""
ls -l /system/xbin/su > /data/local/tmp/output 2>&1
export TEMPRANDOM=71701
/system/xbin/su: No such file or directory
END:71701export PS1=""
ls -l /system/bin/su > /data/local/tmp/output 2>&1
export TEMPRANDOM=85680
/system/bin/su: No such file or directory
END:85680export PS1=""
chmod 755 /data/local/tmp/busybox > /data/local/tmp/output 2>&1
export TEMPRANDOM=13769
END:13769export PS1=""
/data/local/tmp/busybox whoami > /data/local/tmp/output 2>&1
export TEMPRANDOM=21096
whoami: unknown uid 2000
END:21096export PS1=""
rm /data/local/tmp/boomsh > /data/local/tmp/output 2>&1
export TEMPRANDOM=78056
rm failed for /data/local/tmp/boomsh, No such file or directory
END:78056export PS1=""
rm /data/local/tmp/sh > /data/local/tmp/output 2>&1
export TEMPRANDOM=87999
rm failed for /data/local/tmp/sh, No such file or directory
END:87999export PS1=""
chmod 700 /data/local/tmp/zergRush > /data/local/tmp/output 2>&1
export TEMPRANDOM=36119
END:36119export PS1=""
cd /data/local/tmp/ > /data/local/tmp/output 2>&1
export TEMPRANDOM=74317
END:74317export PS1=""
export TEMPRANDOM=10407;export PS1=END:$TEMPRANDOM;./zergRush
[**] Zerg rush - Android 2.2/2.3 local root
[**] (C) 2011 Revolutionary. All rights reserved.
[**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
[+] Found a GingerBread ! 0x00000118
[*] Scooting ...
[*] Sending 149 zerglings ...
[*] Sending 189 zerglings ...
[-] Hellions with BLUE flames !
END:10407export PS1=""
export PS1=""
/data/local/tmp/busybox mount -o rw,remount /system > /data/local/tmp/output 2>&1
export TEMPRANDOM=84108
mount: permission denied (are you root?)
END:84108export PS1=""
/data/local/tmp/busybox mount > /data/local/tmp/output 2>&1
export TEMPRANDOM=73571
rootfs on / type rootfs (ro,relatime)
tmpfs on /dev type tmpfs (rw,relatime,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
none on /acct type cgroup (rw,relatime,cpuacct)
tmpfs on /mnt/asec type tmpfs (rw,relatime,mode=755,gid=1000)
tmpfs on /mnt/obb type tmpfs (rw,relatime,mode=755,gid=1000)
none on /dev/cpuctl type cgroup (rw,relatime,cpu)
/dev/block/mtdblock2 on /system type yaffs2 (rw,relatime)
/dev/block/mtdblock4 on /data type yaffs2 (rw,nosuid,nodev,relatime)
/dev/block/mtdblock5 on /persist type yaffs2 (rw,nosuid,nodev,relatime)
/dev/block/mtdblock3 on /cache type yaffs2 (rw,nosuid,nodev,relatime)
END:73571export PS1=""
/data/local/tmp/busybox mount -o rw,remount /dev/block/mtdblock2 /system > /data/local/tmp/output 2>&1
export TEMPRANDOM=38286
END:38286export PS1=""
export TEMPRANDOM=62208
END:62208export PS1=""
export TEMPRANDOM=61164
mount: Operation not permitted
END:61164
$ export PS1=""
2.3.3
CASIO
C771
[*] Scooting ...
export PS1=""
END:61164
