HBO Go and Nexus 7 2.0
Agapens
Went to download the HBOGO app for my new Nexus 7 and it says its incompatible. Anyone have any luck sideloading it? :confused:
This tends to happen whenever a new version of Android is released, a number of apps don't work as they're only listed as being compatible with certain Android versions. They do actually work fine, but don't recognise 4.3.
Hopefully you're not waiting too long for a fix.
Probably not until HBO adds the N7 2.0 (or I guess 4.3) to the list of approved devices/OS. Its mainly because they probably have to make sure it works with their DRM scheme and such. I'd give it another week or so.
Perfect example of Fragmentation. Something that has been a thorn in Android's side for a long long time. Too many diff devices running diff versions along with apps that only work with a combo of devices/versions. It's a mess.
OK..nothing to do but wait I guess. it does work on my phone BTW. the Verizon rep told me they were releasing these upgrades in small waves of 1000 each.
Sideload the HBO GO 2.0.1 apk - you'll be good to go.
