Hi
I have rooted and s-off'ed my Desire using the noob guide on XDA. I flashed the Insertcoin ROM and more recently the SGBS. On both accounts I used the A2SD versions. Both worked ok.
Am I right in saying the CM7 versions will be quicker as some parts are stored on the internal memeory?
Am I also right in saying I need to flash the HBoot before I can use the CM7 versions?
If so, I'm confused by what to use to flash the HBoot. The AlphaRev site has a table about half way down the main page. Im confused by what the Download and PB99IMG colums are for? What file do I need?
Also, can I use Android flasher to flash the HBoot? Is this the best and safest way?
Thanks
Thanks
