Help HD games a problem !!
cool.gautam
I just wanted to know that why all HD games even HVGA or simple games lag on our phone?
it has 600mHz processor with adreno 200 GPU and same specs stand for galaxy mini which my friend owns.
i downloaded many HD hvga version games all were lagging on my phone but not on my friend's phone.i feel humiliated though :P
i just wanted to know even freeing about 85+mb ram + quadrant 800 avg. WHY GAME LAGS any REASON OR SOLUTION..( i know quadrant is not only the determining factor)
On GB Bootloader ,Samsung allocated more ram to GPU . Thats why we have a very snappy GB .The performance of 667Mhz Froyo and 480Mhz Gingerbread was same . It's probably the same case with GMini .
Oh btw QD scores dont matter much .All samsung can go 1600 on modified Stock GB and aroung 2300 on Full Custom GB .
Try using 600Mhz with performance governor while playing games .Thats the most you can do
Galaxy Mini is having 240x320 Screen. Which reduces the number of pixel calculations and reduces the load on both CPU and GPU. But anything with 240x320 is not HD. :p
@samroxx
I dont think anything is possible without the source . It should actually be done to by a A70 user since he will be able to quickly troubleshoot .
The level of complexity is high IMO .
It took 8 months to port CM on our phone (with partial source ) and still it is not fully working .
That level of commitment is only if
A)You get paid to make ROMs
B)You are passionate about your device
you are right a 70 users can try it...
i had to test the rom in emulator to see if it boots up or not
if you have high speed internet then you can try it ..the source is 4gb it will take 2hours to download it and you should have ubuntu on system
can i download ubuntu on my own?
i am finally leaving reliance n moving on to photon+
maybe speed incr. give the links
Galaxy Mini also has 328 mb ram vs our 256..
Our phone is at par with X8 and GT540
Op1, Mini, Fit, Ace, Wildfire S are marginally better than A70 (atleast until CM7 :P)
To compile or build a Rom based on aosp you need ubuntu because source is downloaded through ubunto not like normal downloads...
In cygwin some times the files gets corrupted while making a Rom.. like wifi
