Help HD games on Note
pb123
Heya guys,
Sorry if this has been posted before. I did look through the post but couldnt find anything.
Anyways I upgraded from MY HTC Desire HD to Samsung Galaxy Note.
But I've been having problems with HD games.
I brought Shadow Guardian, Sacred Odyssey HD which worked great on my HTC but on Note it wouldn't download the data or will download it but you cant play it (cant see the graphics/ white screen etc)
I'm just wondering is there a way to get these games to work on note without needing to root the device. Even though I know how to root android I don't want to do it on a new device and kill the warranty.
Other HD games I can play?
Thanks
you can go for Asphalt 6 available free on Samsung Market. Im looking forward for Asphalt 7 (heat) to get available on Google Play..
I bought NFS shift but that does not work. I hate them for cheating.
check out on google play.. u would find other recommendations as well.
thekripton...
there are infact 2 versions of nfs shift, only one is compatible with the note...maybe you bought the incompatible version...just a thought.
regards
Baz
thekripton...
regards
Baz
Android market never let u buy the in-compatible version!!
Yes, there are two versions.. and i bought the Compatible One.
PS.. i have learned this:::
Before buying anything from market, go to user-reviews and select reviews of ur own model (Note).. by this..u get a lot of info about the app before buying. :)
Have you tried to email them to see what they say?
I got asphalt now thanks but still looking for an adventure type game.
i havent tried this but im sure that they wont do anything about it..
a huge bunch of ppl have commented bad things about the developer but none of them got their money back.. nor google seems interested to remove such apps from the market..
