HDFC Bank MobileBanking not compatible with A70
ulfattu
Hello,
Few days before HDFC launced there official android app but the play store is not displaying the same app.
I tried installing from https://play.google.com using a PC browser instead but was not able to install it.
In both case the system displayed that "This app is incompatible with your Vodafone IN Micromax Micromax_A70".
Can anyone of you please confirm if theay are able to install the HDFC mobilebanking android app.
Regards
Ulfattu
Dear ulfattu,
its available now, please check again.
i think they have done some updations, it was not available for ICS as well some days back...I have installed it & using.
great thing is its just .99 mb in size.
Dear ulfattu,
Thank you A70, yes now its available and I have installed it.
