Anthony2816
Has anyone found an HDMI cable that will allow me to hook my S3 display to my big screen TV? I bought one from NewEgg, but it didn't work...the seller eventually decided it was only for the S2.
Take note only the Samsung MHL adapter works do not try to use a standard MHL Adapter. The S3 has diff pins and only the MHL adapter from Samsung works
HDTV Adapter (5 Pin) w/ HDTV Adapter Tip
oop's my bad I ment to grab the 11 pin linkNegative. Do not use this link. This is NOT for the S3. 5 pin is old 1.0 HML standard.
You want this: Samsung EPL-3FHUBEGSTA HDTV MHL Smart 11 PIN micro usb to hdmi adapter specifically for the Galaxy S3.
Check ebay. The 'real' ones will cost between $35 and $45. Do not be tempted by lower costing ones. Trust me on this!
HDTV Universal Adapter (11 Pin) )
No worries I'm glad glad you saw that. I agree I hate to see people waste good money too. That's part of what we do is help each other. GO TEAM USA!!! sorry had to add that part.No worries. I got suckered into one of those 5 pin ones, when the phone first came out here, cause it was labeled as an S3 accessory online. People then found out these didn't work. Then I tried the 5 to 11 pin adaptor piece. That still won't work. You HAVE to get the Samsung dongle, because of the new MHL 2.0 standard built into the S3.
Just don't want anyone to make the same mistake as me and waste money. There was no negative intent meant towards your post. Hope it didn't come off that way?![]()
Can anyone tell me if the power port on the Samsung HDMI adapter will also charge the phone while you are watching a movie through the HDMI cable. My droid Charge had a dedicated HDMI port so you were able to keep the phone connected to the charger through the micro usb at the same time.
If not, how do you keep the phone charged while using the HDMI?
With these adapters do you have to use a standard HDMI cable like you would use from cable box to TV or do you use the micro HDMI to standard HDMI cable?
It'll mirroring your phone's display on TV
Harry
I got the Skivia adapter on Amazon after seeing it had a large number of positive reviews:
Amazon.com: Skiva MHL Micro USB to male HDMI cable (6.5 feet) for Samsung Galaxy S3 (SIII LTE i9300 L710 i747 i535 T999) and Samsung Note 2 Smarphones (HD-X3): Electronics
It seems to work alright, although on my HDTV it seems like the picture is "zoomed" a little and all four edges are cropped off a little. I'm thinking it must be my TV though since I haven't seen anyone else listing this issue within the product reviews...
I might have returned it because of this issue if it weren't a gift, so it cost me nothing.
Yes, routing the audio stream like that would work. But you'd have a shorter signal path if you connected the phone directly to the receiver. This could be accomplished either via HDMI (if your receiver is capable) or an auxiliary cable from the headphone jack.
